Connect/loft/sweep circle with rectangle
I want to make a pillar. Unfortunately, I am not satisfied with the result. it’s twisted :smiley:
column.3dm (494.2 KB)
column.gh (12.3 KB)
Does someone have an idea? Thanks
I studied your code for awhile, confused by the rotations, and finally realized that the start points for the rectangle and circles don’t match. Two ways to fix that:
Adjust the Seam of the circle (before it is copied/moved) to match the rectangle: (yellow group)
circle_rectangle_2021Oct19a.gh (14.8 KB)
Or use the Loft Options and check the ‘Align sections’ box:
circle_rectangle_2021Oct19b.gh (12.3 KB)
Thanks a lot Joseph. It works :ok_hand: :+1:
