Connect connect command won't work
All,
Possible bug. In the attached file the Connect command won’t trim the lines back to a corner. Redrawing a similar box seems to work fine so the work around isn’t a big deal but unless I’m missing something this “should” work. Yes?
Dave
Connect_Bad.3dm (42.0 KB)
Hi Dave- something is certainly wrong here- thanks… still poking.
Ok- the rectangle curves are not quite in plane with the long line - try ProjectToCPlane > DeleteInput=Yes and it should go…
