I am confused about what I am seeing with this network surface (called curve network in Matrix).
when I zoom in, the surface looks like it is pulling away from the red curve, which is actually a dup edge of this surface (I have since deleted the original input curve for that surface.
when I complete the rest of the surfaces, and join everything up, and check using show edges, I get no naked edges in this area.
My question is, is it still a naked edge? (even though it is not reading as one?) or just a visual thing due to my computer of graphics card or something?
I am running:
Intel I&-4770K, 16gb ram, 2T hdâŚ
Nvidia GEForce GTX 760
That is probably just a render mesh issue. Switch to wireframe display to check if you can see a gap. I guess you wonât see it if there an no naked edges. Go to Document Properties - Mesh - select âSmooth & slowerâ to use a denser render mesh.
Thank you for your quick reply, I really appreciate it.
Ok, so:
I switched to wire frame, and did not see another edge curve, or a gap, so I am hoping that this is ok.
I switched from âcustomâ (80% density) to smooth and slower, and this reduced the anomoly, but did not resolve it.
3a) I switched back to âcustomâ and changed density from 80% to 100% and that reduced the anomoly a bit as well, but did not resolve it.
3b) However, one much appreciated benefit is that changing to this "custom/ 100% density " setting, my panning while in lots of zoom has greatly increased its performance.
(Prior, if I was zoomed in, and then tried to pan, it was like microscopic movement, and I would have to zoom out, pan, and zoom back in again.,.)
may I ask the pros and cons for each of these settings? I am not quite clear on why one versus the other?
Go into Detailed controls under Custom in Mesh and try adjusting some of the settings ; in particular maximum length of edges and maximum distance from edge to surface.
This is not likely to be due to the mesh setting, it just happens that you reset the target in that view at the time you made the change to the render meshes. The slowdown happens when the camera eye point gets very close to the target point in a perspective view, as can happen with Zooming via scroll or Zoom Window. I suggest using Zoom Target (right click on the Zoom Window button by default) to reset the camera and target from time to time or when this slowdown in dynamic zoom occursâŚ
Hi Julie - The link should be the right one but the McNeel Wiki seems to be broken at the moment - sorry for the inconvenience, weâll see if we can get that back in action.
âŚ
This should work now- it seems to be very slow still, but it works.
I understand how to get to the âZoom targetâ function, but can you advise on âhowâ to âresetâ the camera and target, please> I am not clear on this concept
I got to step one, and saw the asterick-like icon pointer, but then did not know what to do (or why) after thatâŚ)
Hi Julie- Zoom Target works be setting the target point and then making a rectangle all around that point that will be the zoom frame - the smaller the rectangle, the more zoom. So the workflow is best if you have an object snap going- say End: ZoomTarget and at the cross-hairs cursor (This tells you that Rhino is looking for a point in space) snap to an and point, mouse down and then drag a little rectangle around the point and let go of the mouse button. This âresetsâ the camera and target relationship so that scroll-zooming is a little more useful and predictable. Note that if you zoom in really really tight and you want to maneuver the view around it pays to set the view projection to parallel - it will work better than in Perspective projection.
