I am getting this error message after the installation of Pufferfish, how can we resolve this?
maybe you did install it manually (drag and drop files into Libraries) and also installed it from PackageManager ?
Hi Thank you for the reply,
I have only manually dragged and dropped it into the folder ( did not install through Package manager)
however, I have dragged and dropped twice (Deleted the first instance and replaced it again)
Just checked on PackageManager, and looks like Putterfish is not present there
that error indicates that GH has found duplicates of the same things: the different “Assembly” file paths indicate where they are located in your hard drive
I’d suggest to delete the first one as it looks like the second one is V3, latest version
Yes, the error message disappeared after following your instructions
Thank you for your Hep
