Hello Guys
when I use the Draw Full Names function, the following situation occurs: the parameters x and y expression stop working normally and ask to make changes to the parameters.
Hello Guys
I cannot reproduce that bug here.
pls run _SystemInfo and post back the results
Record a video?
sis.txt (2.9 KB)
This is a well known and long standing bug in GH. VERY OLD
Rename the inputs from “Variable x” to “x”.
when from Full Names you go back to short names, or the opposite, or change variable name, then you need to right click → Recompute or reconnect at least one of its inputs, to let the component refresh (which I believe is the situation in this picture, still to be refreshed)
I often use Expression since version 5 of Rhino, and this is the first time I came across it, and we have 12 versions bought on 4 machines, this is the only thing
Avoid “Draw Full Names”
