I am doing a lot more Skype/Zoom meetings at the moment with multiple different clients and find it extremely difficult to avoid inadvertenly showing the wrong client a screenshot of what I’m working on for another client when sharing my screen during a call.
I figured out how to turn off the splash screen on startup (by adding \nosplash to the shortcut ‘Target’ address in properties). But whenever I go to open or export a file it remembers the previously used location - which of course is full of thumbnails of all my files. How can I turn this off? or better yet set a specific location to go to?
I’ve found the ‘Clear Recent Files List’ button in Options - Files - which seems to acheive what I want when I press it. But I’d rather an option to not record recent files in the first place. I don’t suppose there’s any workaround to run this as a command on shutdown?
For the duration of your virtual meeting you could also just turn off showing of icons in thumbnails, or thumbnails in general (in Windows).
Anyway, in Rhino 6 you can use also - prior to your meeting:
Tools > Options > Advanced. Type Recent in the search bar for advanced settings, select the triple-dot button after Rhino.RecentFiles and copy/paste the list to notepad. Then empty the content and save.
Then search for OpenAndSaveDirectory, and set the value to what you want it to be. You may want to go through all entries for DefaultFileDialogDirectories
Restart Rhino after this, and double-check that opening file now goes to the folder you entered in the second step. The first one you probably already knew.
Thanks ajarindia, I’ve checked that. I’m up to date with .NET.
David’s .exe file runs ok, but it only says: “Deleting File: grasshopper_mru.xml” no mention of any Rhino settings change. When I re-open Rhino all the recent file information is still there.
Thanks Nathan, some good suggestions, but I really need something that I don’t need to remember to do every single time. It’s not just potentially embarassing, it could utlimately lead to legal issues for breach of NDA’s etc.
I’ve tried changing the OpenAndSaveDirectory as you suggested and it doesn’t seem to work? I set the value to a new folder, closed Rhino and restarted, but it still went to the previously saved folder. I went back into options and it had changed it back again.
It’s a fairly clunky work around though. Is there a command I could use to run the “Clear Recent Files List” option from the Rhino Options / Files Section? That appears to do exactly what I want if I could add that to a macro it would be perfect.
To complete the workaround I added “Call Rhino.Command(”_SelAll _Export ““C:\Users\USERNAME\Desktop\Nuthin.3dm”” _Enter", 0) after opening C:\Users\USERNAME\Desktop\Nuthin.3dm in order to reset the Export file location as well.
Final macro/script:
! -_Runscript (
Call Main()
Sub Main()
Call Rhino.Command("_Open ““C:\Users\USERNAME\Desktop\Nuthin.3dm”” _Enter", 0)
Call Rhino.Command("_SelAll _Export ““C:\Users\USERNAME\Desktop\Nuthin.3dm”” _Enter", 0)
Rhino.Exit
End Sub
