Is there any simple way to create a cone where the point is not directly over the center of the base?
Create a circle where you want the base of the cone, create a point were you want the point, call Loft, select the circle, then choose the Point option in the loft command, and snap to the point you created (if you have something else you are snapping to, you don’t need to actually create the point).
Sam
Thanks, That works.
Also, ExtrudeCrvToPoint
, in case you get bored lofting.
