ON_Cone::IsValid() in opennurbs_cone.cpp, line 59:
return (plane.IsValid() && height != 0.0 && radius != 0.0);
Should radius be tested on radius > 0.0 ? If negative radius is accepted (as a cone with inward directed normal - ON_Cone::NormalAt), than it is not clear why ON_Cone::CircleAt assumes that the radius is positive creating/manipulating a circle (which will be invalid in case of negative radius) without any checks. And why ON_Cone::Transform is always invalid for an “inverted” cone with negative radius…
Best regards,
Leo
