Conduit CallbackOnCollectedDelegate
In my plugin,
Managed Debugging Assistant 'CallbackOnCollectedDelegate' : ''RhinoCommon!Rhino.Display.DisplayPipeline+ConduitCallback::Invoke'
this error usually happen.
When I build my plugin in debug mode, that error never happen. It happen only release build.
 public class MyConduit : Rhino.Display.DisplayConduit, IMyDomainRenderObject
        public List<(Polyline, Color)> Polylines { get; set; }
        public RhinoDoc Doc { get; set; }
        protected override void DrawForeground(Rhino.Display.DrawEventArgs e)
            if (this.Polylines != null)
                foreach ((Polyline polyline, Color color) in this.Polylines)
                    e.Display.DrawPolyline(polyline, color);
                e.Display.EnableLighting(true);
my conduit is simple.
When I create some polyline in my plugin, just render it.
conduit object is stored in my ViewModel.
if my ViewModel is deleted, I changed its all conduits to UnEnabled before deleting ViewModel.
Do anybody know some possible situation ??
  • Kyungmin
Hi @kyungmin.so,
Can you provide sample source code, that we can run here, along with step-by-step instructions on how to repeat what you are seeing?
Thanks,
– Dale
Hello @dale
I want provide sample code, but It is related third private library.
And, It is hard to reproduce that case.
If I create sample source code, I will post again.
Thank you for your support.
  • Kyungmin
