Hi Tay and Wim,
system information:
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Commercial, build 2021-02-03
License details: Cloud Zoo. In use by: parr.will ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: LAPTOP-6UVNRB1R
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 4-16-2020 (M-D-Y).
> External USB display device with 2 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Primary OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-19-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.8280
> Integrated (slow!) graphics device with 3 adapter port(s)
- Secondary monitor is laptopâs integrated screen or built-in port
Secondary graphics devices.
NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 10-9-2020 (M-D-Y).
> Integrated acclerated graphics device with 1 adapter port(s)
- This device is not being used
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
The âMain Displayâ is conncected to an external USB display port device, which is preventing the
proper video drivers from being loaded by Windows.
- Recommended:
- Use Windowsâ Display Settings to configure the laptop screen as the âMain Displayâ.
- Or, unplug a monitor and plug it into a built-in video port (HDMI/DP) on the laptop.
Then use Windowsâ Display Settings to configure that monitor to be the âMain Displayâ.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.8280
Driver Date: 5-19-2020
Driver Version: 27.20.100.8280
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp âCommandsâ 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp âRhino Renderâ
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp âDisplacementâ
I donât think itâs a problem with a specific model, as it happens with most of my files. Hopefully you can see something in the system info.
thanks and best wishes,
Will
