Rhino 6 and Windows 10
My desktop computer has twice locked and the only way to recover it was to power down.
I imported 13 meshes into a new file. Most of the meshes have over one million faces. The file will be used as background after I scale and position the meshes. I have not done any transformations to the meshes yet. The meshes pan, rotate and zoom smoothly.
The first time the computer locked I was using BoundingBox on the meshes. The second time it locked I clicked on one of the colors on the layer panel. Both times it completely locked and the only way to recover was to power down.
I have previously used a set of meshes of about the same total size, most of which are also used in this file, without any problems. I did update the latest SRC yesterday.
SystemInfo and file audit info below:
System info
Rhino 6 SR27 2020-5-26 (Rhino 6, 6.27.20147.08371, Git hash:master @ 1e9a6eee0e449d46c9d8683989bd9e29371fd694)
License type: Commercial, build 2020-05-26
License details: Cloud Zoo. In use by: David Cockey ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-7M1R2N0
Non-hybrid graphics.
Primary display and OpenGL: AMD Radeon HD 7700 Series (AMD) Memory: 2GB, Driver date: 8-16-2019 (M-D-Y). OpenGL Ver: 4.6.13559 Compatibility Profile Context 26.20.12028.2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-16-2019
Driver Version: 26.20.12028.2
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.27.20147.8371
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.27.20147.8371
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.5.0
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.27.20147.8371
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.27.20147.8371
File Audit
Testing 3dm Archive: C:\Current Projects\Vega\Rhino\VegaImport28May.3dm
Start Section: 452 bytes (offset 0 to 452)
Offset: 0
3dm archive version: 60
Interface Name: Rhinoceros 6.27 - Commercial, build 2020-05-26 - (compiled May 26 2020)
SDK Version: 2348836105.2355918077
OpenNURBS Version: 2355918077
3dm Version: 6
Operating System: Windows 10.0 SR0.0 or greater, 64-bit, platform 0, version 10.0 build 0 sp 0.0, suite 0, product type 0
Runtime: ON::RuntimeEnvironment::Windows 3DM I/O processor: OpenNURBS toolkit version 2355918077 (compiled on May 26 2020)
Properties Section: 132070 bytes (offset 452 to 132522)
3dm archive openNURBS version: 2355918077 (6.27 2020-05-26:1)
Application Information:
URL: “http://www.rhino3d.com”
Details: “Commercial, build 2020-05-26”
Revision History:
Create Time: Tuesday May 19 22:22:12 2020 UCT
Last Edit Time: Thursday May 28 14:59:32 2020 UCT
Revision Count: 7
Created By: “David”
Last Edit By: “David”
Settings Section: 15151 bytes (offset 132522 to 147673)
Length unit system: inches
Plug-ins:
Name: 3Dconnexion 3D Mouse
Version: 6.27.20147.08371
File: C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp
SDK Version: C++ 2348836105.2355918077 (6.0 2017-08-15:1, 6.27 2020-05-26:1)
Version: 6.27.20147.8371
File: C:\Program Files\Rhino 6\Plug-ins\Commands.rhp
SDK Version: .NET 0.0
Version: May 26 2020 09:01:40
File: C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp
File: C:\Program Files\Rhino 6\Plug-ins\import_OBJ.rhp
Version: 2.0.6954.25689
File: C:\Program Files\Orca3D V2\Orca3D.rhp
File: C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp
Name: Renderer Development Kit
Version: May 26 2020 08:56:20
File: C:\Program Files\Rhino 6\Plug-ins\rdk.rhp
Name: Renderer Development Kit UI
Version: May 26 2020 08:58:01
File: C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp
Version: 1.50, May 26 2020, 08:57:36
File: C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp
File: C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp
Name: SimLab PDF Exporter
Version: Feb 6 2018
File: C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp
SDK Version: C++ 2348836105.2348836701 (6.0 2017-08-15:1, 6.0 2018-01-09:1)
Version: May 26 2020 09:02:51
File: C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp
File: C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp
Embedded image Table:
0 embedded images, 24 bytes (offset 147673 to 147697)
Texture Mapping Table:
0 texture mappings, 24 bytes (offset 147697 to 147721)
Material Table:
material[0]: Solid
material[1]: Solid
material[2]: Solid
material[3]: Solid
material[4]: Solid
material[5]: Solid
material[6]: Measures
material[7]: Keel1
material[8]: Keel11
material[9]: Keel12
material[10]: Keel13
material[11]: Keel14
material[12]: Keel15
material[13]: Keel16
material[14]: Keel17
material[15]: Rail
material[16]: Rail1
material[17]: Rail2
material[18]: Rail3
material[19]: Rail4
material[20]: Rail5
material[21]: Rail6
material[22]: Rail7
material[23]: Stem
material[24]: Stem1
material[25]: Stem2
material[26]: Stem3
material[27]: Stem4
material[28]: Stem5
material[29]: Stem6
material[30]: Stem7
material[31]: SRab
material[32]: SRab1
material[33]: SRab2
material[34]: SRab3
material[35]: SRab4
material[36]: SRab5
material[37]: SRab6
material[38]: SRab7
material[39]: Yard11
material[40]: Yard2
material[41]: Yard21
material[42]: Yard3
material[43]: Yard31
material[44]: Yard4
material[45]: Yard41
material[46]: Yard5
material[47]: Yard51
48 materials, 48978 bytes (offset 147721 to 196699)
Linetype Table:
0 linetypes, 24 bytes (offset 196699 to 196723)
Layer Table:
layer[0]: Default
layer[1]: MRail1
layer[2]: MRail2
layer[3]: Hull1
layer[4]: Hull2
layer[5]: Hull3
layer[6]: Hull4
layer[7]: Measures
layer[8]: Keel
layer[9]: Rail
layer[10]: SRab
layer[11]: Stem
layer[12]: Yards
13 layers, 3202 bytes (offset 196723 to 199925)
Group Table:
0 groups, 24 bytes (offset 199925 to 199949)
Annotation Style Table:
annotation style[0]: Default
annotation style[1]: Inch Decimal
annotation style[2]: Inch Fractional
annotation style[3]: Foot-Inch Architectural
4 annotation styles, 5626 bytes (offset 199949 to 205575)
Light Table:
0 lights, 24 bytes (offset 205575 to 205599)
HatchPattern Table:
0 hatchpatterns, 24 bytes (offset 205599 to 205623)
Block Definition Table:
0 block definitions, 24 bytes (offset 205623 to 205647)
Object Table:
object[0]: 3362462 bytes, id = 5e0f2bc9-032f-479b-a087-31de97624b1b, name = “”
object[1]: 3424468 bytes, id = 731dc78c-8219-4e61-a6cf-adf8439373de, name = “”
object[2]: 4856891 bytes, id = 4eaff594-8996-4bc6-bc47-4763d62b3475, name = “”
object[3]: 4948566 bytes, id = 9a8df928-2fd8-44a9-9312-f5e8b8112d0e, name = “”
object[4]: 3210544 bytes, id = 305c153e-e785-4ef1-b43e-37d6a5ec1c6a, name = “”
object[5]: 3347316 bytes, id = 4b4c374a-c922-48c1-821a-c78f3075a37e, name = “”
object[6]: 3309858 bytes, id = f3c786e3-da4a-4ef8-9763-a005097d4d48, name = “”
object[7]: 3539376 bytes, id = a1dd166c-fa58-4e60-b52a-3e2a9d454ae1, name = “”
object[8]: 3049171 bytes, id = cfc3a703-b3f3-48b7-88c0-13fa4e6a6637, name = “”
object[9]: 5318451 bytes, id = a292d79f-c13a-4a6f-9d5e-f09d831fce50, name = “”
object[10]: 5512817 bytes, id = 4f064487-2c9b-437f-8aea-24416ae77508, name = “”
object[11]: 6027495 bytes, id = 2f29b24c-9269-4c5f-be96-3c0c97d94853, name = “”
object[12]: 6519868 bytes, id = bf289d0b-0c36-477f-8c30-7b779f8d4661, name = “”
object[13]: 5883076 bytes, id = 4f15a524-d113-4d68-98a3-90a05cedea75, name = “”
object[14]: 4563398 bytes, id = c8416f1b-e2f1-4262-a91c-640455efdcc5, name = “”
object[15]: 5669289 bytes, id = 332a9cf7-f169-42ad-8dec-2341f03a9415, name = “”
object[16]: 4218264 bytes, id = d6ce9f13-3710-4bf3-9d21-9932f88b8fb4, name = “”
object[17]: 6113223 bytes, id = bf8ee63d-7d43-4a6a-88ae-d52f0bbfae57, name = “”
object[18]: 6204489 bytes, id = 5e310bb3-ce8d-4898-876c-7b76307065ea, name = “”
object[19]: 5984193 bytes, id = 397da59a-2d8a-47d9-b284-a9276bb0f034, name = “”
object[20]: 6431551 bytes, id = ec9dec77-77b0-4e02-a3eb-43f4e4a0ffc4, name = “”
object[21]: 4278110 bytes, id = 9f77b844-8033-4c53-9fda-6b4001ab2441, name = “”
object[22]: 5784009 bytes, id = 20e640f3-64d0-48eb-b5de-b7f791f5a390, name = “”
object[23]: 4458872 bytes, id = 4a76e53a-fa33-417e-a214-5cd2eeea992d, name = “”
object[24]: 5739512 bytes, id = eac5db4a-e23d-4b3d-a308-7c7ea747810b, name = “”
object[25]: 12479048 bytes, id = 2a155306-6315-490b-95d8-769aced39a33, name = “”
object[26]: 12843540 bytes, id = 2b628b7f-9d39-48cc-8f07-ae50723ec8dd, name = “”
object[27]: 12521393 bytes, id = c2afd893-fc23-4524-a07d-25810ce5ab8a, name = “”
object[28]: 12730767 bytes, id = 3b466165-26fd-4e76-8462-fdefad0f2024, name = “”
object[29]: 12553012 bytes, id = 629e0f39-3d6e-4caa-b686-4b57bb2a4d98, name = “”
object[30]: 13158650 bytes, id = 556d6ba9-d4f5-4692-9ff7-a9ee90d0c0a5, name = “”
object[31]: 12815228 bytes, id = ba99050c-3e6b-4621-ab79-86082e620134, name = “”
object[32]: 12723577 bytes, id = 67c7fadf-fe1d-4f17-95eb-f3fdd55f33f4, name = “”
object[33]: 2606745 bytes, id = cfb623bd-c64f-49df-813f-4f2506404e0b, name = “”
object[34]: 2684502 bytes, id = 0bc86a2d-3410-43a5-8ad0-e7fa811a912f, name = “”
object[35]: 2405358 bytes, id = 87414a29-37d0-4e24-8660-22497d362231, name = “”
object[36]: 2707076 bytes, id = 6bf62189-80f2-43fd-bc8f-8c38cc27985b, name = “”
object[37]: 2937127 bytes, id = 46db1da7-3c39-4234-bcda-c5fea68fbe29, name = “”
object[38]: 2496507 bytes, id = 3f1440d0-0c6d-4bf6-aa10-eb1a690d4810, name = “”
object[39]: 2180840 bytes, id = 04712c0e-30ea-45b8-9f24-9cc98ffa2bb5, name = “”
object[40]: 2646552 bytes, id = 023aa544-5f6c-4921-92b1-7cf87e2ab965, name = “”
object[41]: 23108085 bytes, id = 1b9b9689-c1cf-4d91-bcca-a73349f84b3f, name = “”
object[42]: 138469159 bytes, id = 735ec65e-6e71-4223-b144-972c26e0f421, name = “”
object[43]: 81746986 bytes, id = 07dfdbd9-8d80-4d1e-9d97-7f9a88ab7666, name = “”
object[44]: 139396845 bytes, id = d4d75ca8-ad8b-41c1-af1d-5e0542b3b20f, name = “”
object[45]: 163041765 bytes, id = 03bd5a55-c788-4e57-aa75-0ce05974e129, name = “”
object[46]: 108583510 bytes, id = 71ff2e13-1443-4698-8628-bac84b8f374c, name = “”
object[47]: 141374049 bytes, id = df744912-e059-473e-b1c1-22139292e953, name = “”
48 objects, 1039965614 bytes (offset 205647 to 1040171261)
History Record Table:
0 history records, 24 bytes (offset 1040171261 to 1040171285)
Model User Data Table:
user table[0]: (82886943 bytes)
Plug-in name: Renderer Development Kit
Plug-in id: 16592D58-4A2F-401d-BF5E-3B87741C1B1B
user table[1]: (497 bytes)
Plug-in name: Rhino Render
Plug-in id: 5DC0192D-73DC-44f5-9141-8E72542E792D
user table[2]: (10087 bytes)
Plug-in name: Orca3D
Plug-in id: 8B62C204-C421-4422-BE79-085DDF05F02B
3 user tables, 82897830 bytes (offset 1040171285 to 1123069115)
Archive size = 1123069135 bytes (end mark size = 1123069135)
