Hi @luis I am facing issues in setting up the compute local server.
I have followed the steps.
Can you sent the compute server with .exe file that I can use directly.
It would help us very much.
Hey, I ran into the same problem. I looked and found that there is a setup script in the github repository that sets up rhino compute on your server. There is a link to a zip file that seems to have the compiled program.
https://ci.appveyor.com/api/projects/mcneel/compute-rhino3d/artifacts/compute.zip?branch=master
Tested it on my machine locally and it worked.
Hope it helps.
