Compute C# Sample does not work
I’m trying out the C# compute sample from the developer guides( Rhino - Calling Compute with .NET) but it throws System.NotImplementedException when it attemps to run:
intersectionMeshes = Rhino.Compute.MeshCompute.CreateFromBrep(brep, MeshingParameters.FastRenderMesh);
I tried running the CircleCircle sample from the github samples repo ( rhino-developer-samples/compute/cs at 8 · mcneel/rhino-developer-samples · GitHub) and it worked until I updated the Rhino3dm nuget package from 0.2 to 8.17.0. When I updated to 8.17.0 I got the same exception from the developer guides sample.
Has anybody else run into something like this?
I see that for some reason we do not have MeshingParameters serialization implemented, even though they should be exposed:
As a temp workaround until we get this tuned up, you can use the method overload without the meshing parameters:
intersectionMeshes = Rhino.Compute.MeshCompute.CreateFromBrep(brep);
Ahh okay, I’ll use the other method for now. Thanks Luis!
