Compound transformation failing
Hi! I do not understand why compound transform does not work in this case. Please help me to understand. Making transforms one by one works, when i try the same with compound(need it for custom blocks from speckle) it does not give the same result.
compound failing.gh (35.5 KB)
I figured it out. Order in which you plug transforms into merge component matters.
