Composite Sheet
Hello Professionals,
Please how would I start to create Composite folded sheets for fabrication in Grasshopper from Surface?
Hi Wai Yan, There are few factors to consider. Primarily how (and where) you are going to determine like panels & numbering. This needs to be flexible, yet not error prone.
I would recommend learning Elefront 4.3 Components, this will allow you to assign attributes, create relationships between 3D and 2D, as well as export the final products (dwg,dxf, documentation)
Hello Japhy,
Good Morning!
Thank you so much for your advice. Usually, for the fabrication, I’m using Inventor but the Rhino is very new for me. Thank you for sharing. Please if you have any other lessons about Grasshopper fabrication kindly please share the knowledge.
