Component’s icon transparent when Script Editor build target is 7.*
I try to make a component with script and set to ironpython.
After build component with ScriptEditor and draw component icon manually
  • build target set to 7.* and load to grasshopper it’s show transparent icon
    demo icon 7
  • build target set to 8.* it’s show my draw component icon correctly
    demo icon 8
Demo Icon.zip (94.5 KB)
Would you please help how can I fixed it ?
ps. rhino version are 8.6.24074.1001
I logged a ticket to fix this. Thanks for reporting and testing the plugin publishing:
RH-81170 Published components do not show icon on Rhino 7
Thank you very much
By the way just found another annoy message while opening grasshopper
on both Rhino 7 & 8
From above example “Demo Icon.zip” component are working fine even this message are shown
Not sure should I open new topic or just continue on this
Change IronPython to SDK mode
on build target to 7.* , there is error with no output
on built target to 8.*, it’s working fine
8
Sorry to most of this is about build target to 7.*
as I would like to creat component with backward compatible
Yes this is definitely a bug. I logged it in the ticket shared above and will get it fixed. Thanks for reporting
