I’m having a conflict with component IDs from different plugins, Swiflet and PRC. How can this be?
@johannes has already changed this component ID on his end. I have reinstalled both plugins and the problem is still there. What may be cause?
Here is my System Info:
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13002, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Educational, build 2026-09-08
License details: Cloud Zoo
Apple macOS Version 26.5.2 (Build 25F84) (Physical RAM: 64GB)
Mac Model Identifier: Mac14,5
Language: en
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
Color LCD (1512 x 982 @ 120.00Hz)
SC16PM1F (1920 x 1080 @ 60.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libSubstanceImporter.dylib
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libsubstance_ogl3_blend.9.dylib
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libsubstance_linker.9.dylib
/Users/filipeb/.rhinocode/py39-rh8/libpython3.9.dylib
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_ssl.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/libssl.1.1.dylib
/Users/filipeb/.rhinocode/py39-rh8/libcrypto.1.1.dylib
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/math.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/select.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/array.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_struct.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/binascii.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/zlib.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bz2.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_lzma.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/grp.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bisect.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_random.cpython-39-darwin.so
/Users/filipeb/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_sha512.cpython-39-darwin.so
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/ShapeDiver/1.33.0/runtimes/osx-arm64/native/librhino3dm_native.dylib
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/SubstanceImporter.rhp “SubstanceImporter” 2.0.7.0
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Fologram/2024.2.26/Fologram.rhp “Fologram” 2024.2.26.0
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/ggRhinoIFC/26.9.17.8/net48/ggRhinoIFC.rhp “ggRhinoIFC” 26.9.17.8
/Users/filipeb/Library/Application Support/McNeel/Rhinoceros/packages/8.0/GHPick/0.7.1/GHPick.rhp “GHPick” 0.7.1.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.35.26251.13002
