Component for treehelpers
Hi all,
In the latest versions, is there a component that manages this type of list as happens with ListItem, managing the indexes of a simple list?
@0904 I am not quite sure if I understand the question here. Would you mind sending a Grasshopper file that shows the problem?
Thanks for the reply @eirannejad
I was looking for a component similar to listitem that would display lists and trees with a slider as an example of the second Python component.
I thought about this after I posted the question, maybe the reasoning is that if you created the lists or trees in Python, can you handle them in Python.
This may not answer your question.
Once you get a tree there is a level of complexity. This might help.
This is the test I was running. Using Tree access input on both x and y will allow the python component to control how the items interact.
treehelp.gh (8.9 KB)
OK thank @scottd
I hadn’t thought of this solution
outputting using list_to_tree
then I can use the listitem
:+1:
