Component fillet
Is it possible to make the fillet command on VA object,
window profile for example ?
Hi @rachelre do you mean the profile that performs the opening into a wall? In this case you can either create a custom profile from the vaProfileFromCurve command, and assign it to the window style, or create a window from a curve, directly in the model.
If you meant if is it possible to run the fillet command on a Window frame edge, for example, then the answer is no. (In the same way you can’t apply fhe fillet command directly on a Rhino block, since VisualARQ objects are blocks actually). You need to create the window from a block style or from a Grasshopper style (in VisualARQ 2). Or explode the window and apply the fillet on the resulting polysurface.
Best,
