Component error - object expired during a solution
Hi, I’m using rhino7.4 and revit2020.2 with rhino inside revit
I really want use rhino inside revit but when I make script and running, always make error like this
At first, It’s no problem but when I modify curve or script and recompute, It always give me that message and I can’t handling that component.
How can I fix that “The object expired during a solution” error?
Hi @Sillu,
Thanks for reporting it.
It should be fixed if you update from Daily Builds.
WOW, Now it’s perfect! Thank you!
