I’m trying to figure out the best way to construct the attached curves as an extruded series of tube elements for a roof frame (assume they’re all 2"x2" steel structure).
I’ve done this before by extruding each curve first vertically, then horizontally. But it’s time consuming. My naive hope was that I could use the Sweep1Rail command, draw a sweep shape, and sweep each rail. But the Sweep1 command sweeps at the location of the sweep shape, not at the rail. So I would have to copy each sweep-shape instance to the start of the rail.
Is there some way to get it to sweep a single shape at the rail location? In other words, I want to use a single sweep shape for all 110 curves.
Or is there a better way to create a 2"x2" extruded steel frame along each curve? I could also use GH I suppose, but was trying to quickly do it without creating a definition.
