I’d like to reproduce an existing footbrigde for a course. The actual footbridge is pierced with lot of holes.
In my attempt to recreate this I drew a simple pattern and then did a mapping wich resulted In simply bending the pattern instead of warping it as I would like to.
Is there anyway I can do that ?
Thank you !
script passerelle.gh (19.2 KB)
Maybe this?
And these look a lot more like rectangles on the bridge photo, not circles.
You need to make an untrimmed surface, there are different ways to do this, here is a simple (and non accurate) one:
EliAbuRada.gh (36.2 KB)
Maybe this will provide better result thank you
these are indeed rectangles, I just used circle to test if it work great or not
Thank you so much !
I knew it has something to do with untrim surface, so I tried Untrim block but it didn’t work
I’ll try to get how you did that for the next time !
You need pattern like this; maybe with Kangaroo
This indeed looks like a relaxed mesh with Kangaroo or similar, which was then made thick. Good option, because it will give a shape in force equilibrium.
I think @anon39580149 has cracked the method here.
Speaking of structure, this remember me of Gaudi hanging chains
I didn’t knew about kangaroo i’ll check that !
Thanks for the tips !
Funny you should say this
