Compiling the 3dmiotoolkit under linux
Hi all,
I wanted to use the 3dmioToolkit under linux, which was a bit of a hassle. Here’s a small writeup on how to get it going under debian (this is tested under the debian testing distribution, but I think this will work for most of the distributions out there.)
I’m by no means an expert in c++. This is the first time I’ve been able to work/hack a c/c++ project into playing nice.
Prerequisites
  • Make sure you have monodevelop installed, mono and things to install a reasonable .net environment.
  • Make sure you have basic compile tools available. (make, g++, automake, etc).
For debian installing the basic compile tools will be this (possibly some packages missing)
apt-get install mono-complete monodevelop
apt-get install build-essential
Clone the patched rhinocommon git repository
git clone https://github.com/arendvw/rhinocommon
Check out the rhino3dmio-linux branch
git checkout rhino3dmio-linux
And download the opennurbs sources from here and unzip the file in the rhinocommon/c/opennurbs folder.
These changes made it compile and play nice with mono under linux
See the this commit on github
To build the native library
run the make command in c/ folder of the repository. The resulting library will be in c/build/Release-linux/librhino3dmio_native.so.
Alternatively, the method used for the other platforms also works for linux now
./build_native.py -p linux
To build the .net library
  • Open monodevelop and compile the Rhino3dmIO project, by hitting F7. (You may need to select the correct framework first)
Do a test
  • Build the example_read project from monodevelop. There can be a post-build error, that the native library cannot be found. This is not a problem.
  • Copy c/build/Release-linux/librhino3dmio_native.so to examples/rhino3dmio/example_read/bin/Debug/AnyCPU/
  • Run the test with mono example_read.exe -out:test.txt AirCleaner.3dm. test.txt should now contain a dump of AirCleaner.3dm.
I’ve not yet created a pull request, is anyone at the opennurbs team interested in including this in the rhino3dmio-toolkit?
Hi Arend,
Thanks for providing this information.
@stevebaer, is any of this information of interest to you?
– Dale
sure, if you make a pull request we will review it and see if there are any changes that we think would need to be made.
Thanks
Sure, pull request is made.
