Questions:
- Processing-wise, which one is heavier a scripting component or compiled ghpy?
- Do all components become multi-threaded? (even .ghpy?)
Questions:
Computational times are likely similar, maybe there’s a minor speedup with GHPY (just test it to know), loading time is longer for the GHPY, as it’s a new assembly to parse. The purpose of compilation is to provide the working data without the source code. It’s a facility provided by IronPython: clr.CompileModules()
No, this has nothing to do with multi-threading. The execution is unchanged, the same engine executes both.
Do I somehow need to program the ghpython, respectively the .ghpy to use multiple threads, or it switches if computation becomes too big?
As usual, you just need to program the multi-threaded code yourself.
Would it be unacceptable to request a Python example for that, too, @piac ?
I’m not changing any visual attributes
Hi @piac,
As far as I understand this multi-threading is about when completing several tasks inside the same script/ghpy.
How can I run each script/ghpy on a separate (from GH) thread?
Example:
Assume ghpython1 a self-updating component which simply reads from sticky on every calculation then passes the result to the output.
We also have ghpython2 which takes a bunch of inputs and saves them to the sticky that ghpython1 reads.
Now, I would like Grasshopper (all of its single threaded components) to run on one CPU0, ghpython1 to run on CPU1 and ghpython2 to run on CPU2.
Can I do that with any of the System.Threading classes?
(if you think necessary split this thread into a new one only for threading with python)
There’s no simple way of doing that.
Thanks Keyu, I’m not looking for a simple way, only that it works.
I have hundreds of self updating components doing simple things and GH starts lagging.
UPDATE:
Can I somehow in SDK mode make the class MyComponent(component) run using threading? Invoking threading from a def
before the class?
@piac
I saw your reply before you deleted it. Yeah I am learning as I go forward, this is the only way as I use IronPython in my free time while I work with GH. I cannot afford investing Work time into learning IronPython.
