Compare parallel vector directions
Hi all,
i try to compare vector directions of two parallel Lines. (Colinear True/False ?)
Rhino.Geometry.Line.Direction gives me a Vector Objects and i try to compare Vector directions.
Direction1 != Direction2 which is nonsens of course.
These Vectors go in Y direction so X and Z is 0.
is there a way to compare + or - Values or do i need value>0 value<0 value==0 ?
IsParallelTo().
Scroll down the page to see Python example. Notice that this command works with an angle tolerance.
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Vector3d_IsParallelTo.htm
// Rolf
Thanks for the example.
is antiparlell two parallel vectors with opposite directions?
Yes. According to the documentation you interpret the return value like so:
