I’m trying to write a tool that would compare two versions of a Rhino model by identifying which objects have been addded, deleted, and modified. Determining the added and deleted elements seems trivial, as I can use the Ids to identify objects that are new or missing. Determining the objects that are modified seems trickier.
Are there any built-in function(s) of the RhinoCommon SDK which can be used to identify if two RhinoObjects are equal to one another or not? Meaning they have the same geometry, attributes, etc…
There is the CompareGeometry method, but it’s not currently hooked up in Python. It does work in Rhinoscript. I’m not sure about the RhinoCommon SDK, but this might possibly be a clue to help you figure this out.
Most of the basic geometry classes and structs in RhinoCommon have an EpsilonEquals<T>(T other, double tolerance) method that can compare whether two objects are “the same” within a specified tolerance (i.e. epsilon).
