CommandTracker
… which reminds me:
@dale, Could you make a RH6-compatible version of this one?
Hi @wim, the plug-in should work in Rhino 6. Have you tried?
– Dale
Hi @dale,
Yes, I have.
Testing F:[snip]\McNeel - other\CommandTracker.rhp for compatibility…
Compatibility test failed in 0.22s
Unable to load CommandTracker.rhp plug-in.
The plug-in does not appear to be compatible with this version of Rhino
Drag and drop unable to load plug-in F:[snip]\McNeel - other\CommandTracker.rhp
Hi @wim,
See if this works:
https://github.com/dalefugier/CommandTracker/releases
– Dale
Like a charm, @dale. Thanks!
