Commands in V8 are not executuable
when i type commands in v8 it selects some random command falling into the first letters and does not allow me to delete nor to cancel out, it is therefore impossible to use any commands like that.
i also installed the last update the issue remains. i have an older laptop but that can not be the problem i presume.
Untitled.txt (12.0 KB)
I am able to run commands - the current build I have is pretty crashy, but that is apparently a known issue and will be fixed soon.
Rhino 8 SR0 2023-1-11 (Rhino WIP, 8.0.23011.02306, Git hash:master @ 3ed1c93267095b190eba22af232b6662c2af73db)
License type: Commercial, build 2023-01-11
License details: Cloud Zoo
Expires on: 2023-02-25
Apple macOS Version 11.6.8 (Build 20G730) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,3
Language: en-FI (MacOS default)
NVIDIA GeForce GT 750M OpenGL Engine (OpenGL ver:4.1 NVIDIA-16.0.13 )
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.1
  Shading Language: 4.10
  Z-Buffer depth: n/a
  Total Video Memory: 2 GB
  Graphics: NVIDIA GeForce GT 750M
  Displays: Color LCD (295dpi 2x)
Metal GPU Family Apple 0
Metal GPU Family Common 2
Metal GPU Family Mac 1
Graphics processors
  Intel Iris Pro (1536 MB)
  NVIDIA GeForce GT 750M (2 GB)
    Color LCD (1920 x 1200)
USB devices
  Apple Inc.: Apple Internal Keyboard / Trackpad
  Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /usr/lib/swift/libswiftFoundation.dylib
  /usr/lib/swift/libswiftAppKit.dylib
  /usr/lib/swift/libswiftCloudKit.dylib
  /usr/lib/swift/libswiftContacts.dylib
  /usr/lib/swift/libswiftCoreData.dylib
  /Users/nathan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Grasshopper2/2.0.8401-wip.33810/Grasshopper2Plugin.rhp	"Grasshopper2"	2.0.8401.33810
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.0.23011.1002
  /Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.0.23011.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp	"RhinoRoslyn"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp	"Constraints UI"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.0.23011.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.0.23011.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp	"RhinoCPython"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.0.23011.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.0.23011.2306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.0.23011.2306
hm, ok you so you have an identical macbook pro, but your system is a bit older, i have big sur, maybe that causes the hick up? if i type the entire command in one second i get it to run sometimes but any delay in typing causes it to hook up immediately
working with the wip is no fun currently… it loads 10 times longer, even if i get a command to work it all feels a bit sluggish, and switching to testmetal nothing really works except wire view.
i kind of like that you can undock all the panels thouugh it needs a bit cleaning up so i am shy to complain to much there for now.
Well, we both have Big Sur, my version is just a tiny bit older. With current build drawing errors happen in Metal (and some crash, but that is being worked on I believe), but with legacy OpenGL it works pretty much the same as Rhino 7 speed-wise I think.
