Is there a visualARQ command to quotate doors with the typical simbol, line with above the length of the aperture and under its height?
@lucavsnt That’s not currently possible that way (I mean, showing a door elevation and width values one on top of each other with a line in between using the same label).
But you can use the vaTag commnad to show that information in two different tag labels. You need to give a specific format to the Tag object:
- Width: %<element.width>%
- Elevation: %<element.elevation>%
Take into account that you can have more than one property inside the tag label (although not in different lines).
Take a look at this post for more information about this topic: http://www.visualarq.com/support/tips/can-i-put-the-object-dimensions-or-other-information-inside-tags/
