Is there a command to join CV points that are extremely close to each other? Most of the naked edges I get while modeling result from CV points that are just barely apart and sometimes it is difficult to see even when zoomed all the way in.
I’m modeling in Nurbs. I use setPt regularly, but it’s a little bit cumbersome since you can only align points together in orthographic axiis. I was hoping there’d be a stitch equivalent for Nurbs that could snap points together regardless of being in perspective view. MatchSrf has been useful, the drawback is it aligns an entire edge as opposed to just one point.
Hi Justin - if you setPt to all three axes, which is what you are after, I think, then you do not need to care what view or cplane to use - snap to one point or the other or use the Between snap to set both to the average.
