Command Prompt
I would like to implement “Copy=Yes or No” at the command prompt, is there a reference source code?
Like this?
Sash
Hi Artstep
This sample doesn’t seem to have the functionality I’d like.
I guess that’s that then :rofl:
Hi @jack3,
How about this?
private string CopyKey => "Copy";
  var bCopy = Settings.GetBool(CopyKey, false);
  var copyOption = new OptionToggle(bCopy, "No", "Yes");
  var gp = new GetPoint();
  gp.SetCommandPrompt("Point location");
  gp.AddOptionToggle(CopyKey, ref copyOption);
  for (; ; )
    var res = gp.Get();
    if (res == GetResult.Option)
      bCopy = copyOption.CurrentValue;
      continue;
    if (res != GetResult.Point)
      return Result.Cancel;
    break;
  var point = gp.Point();
  doc.Objects.AddPoint(point);
  doc.Views.Redraw();
  Settings.SetBool(CopyKey, bCopy);
  return Result.Success;
– Dale
Yes,Thank you very much!
Hello
Do I always need to use this mesot to have two options on the command line?
