Command Prompt Write Formatted Text
Is there a way to write formatted text to the command prompt?
Thanks!
Interesting request… Why do you need/want to do this?
Well, because it would be nice. The command ran successfully? The report is shown in green. There is a warning? Why not show it in yellow? It failed? Let’s return it in red.
that might mess up the pretty busy screen even more with all these colours shouting… i agree if something fails it could mark it slightly red, or orange depending on which UI mode you are using. but this green then that red and other stuff white might be just too much going on.
Agreed - it was just an example. I don’t want to make a 2001 Space Odyssey psychedelic UI.
