I’ve just installed Mavericks on my mac book pro and downloaded the latest release of rhino but the command prompt doesn’t work properly…it takes time to input the command and as soon as I type in the first letter to recall the command the little rainbow wheel appears…the prompt takes at least 5 seconds to react to my input…does anyone know what that could be!? Thanks in advance for the help
here’s my Open GL info
Software information
Software versions
Rhinoceros version: 5.0 Wenatchee 2013-10-23 (485)
OS X version: Versione 10.9 (Build 13A603)
Plug-ins
None
Hardware information
Computer hardware
Hardware model: MacBookPro9,2
Processor: Intel Core i7-3520M CPU @ 2.90GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel HD Graphics 4000 OpenGL Engine
Memory: (null)
Screen size: 1280 x 800
Displays: LCD colori
USB devices
None
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-8.18.26
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
HI,
I have the same problem. I thought it was my old and glorious mac book pro, but I see that someone else has the same problem with more recent mac book pro.
thanks
here my hardware information:
Riepilogo hardware:
Nome modello: MacBook Pro
Identificatore modello: MacBookPro3,1
Nome processore: Intel Core 2 Duo
Velocità processore: 2,4 GHz
Numero di processori: 1
Numero totale di Core: 2
Cache L2: 4 MB
Memoria: 4 GB
Velocità bus: 800 MHz
Versione Boot ROM: MBP31.0070.B07
Versione SMC (sistema): 1.16f11
Numero di serie (sistema): W8738179X92
Hardware UUID: 00000000-0000-1000-8000-001EC20142D3
Sensore movimento improvviso:
Stato: Abilitato
Nome modello: iMac
Identificatore modello: iMac11,1
Nome processore: Intel Core i7
Velocità processore: 2,8 GHz
Numero totale di Core: 4
Cache L2 (per Core): 256 KB
Cache L3: 8 MB
Memoria: 12 GB
Velocità d’interconnessione processore: 4.8 GT/s
Versione Boot ROM: IM111.0034.B02
Versione SMC (sistema): 1.54f36
Numero di serie (sistema): VM019TZG5RU
Hardware UUID: 050F02B8-5F80-5997-B07B-9E8CE559FD47
ATI Radeon HD 4850:
Modello Chipset: ATI Radeon HD 4850
Tipo: GPU
Bus: PCIe
Larghezza Lane PCIe: x16
VRAM (totale): 512 MB
Fornitore: ATI (0x1002)
ID dispositivo: 0x944a
ID revisione: 0x0000
Revisione ROM: 113-B9110C-425
Versione driver EFI: 01.00.383
Monitor:
iMac:
Tipo di monitor: LCD
Risoluzione: 2560 x 1440
Profondità pixel: Colore 32 bit (ARGB8888)
Monitor principale: Sì
Mirror: Spento
Online: Sì
Integrato: Sì
Tipo di connessione: DisplayPort
I don’t know if can help but seems that some prompt is slower than other. For example prompt start with s…
Yep! right…the prompt seems to be slower with commands starting with S…
Also the new release of Rhino that came out yesterday has the same problem on Mavericks…
Please use the Rhinoceros > Preferences > OpenGL panel for getting your computer settings. There’s a lot more information there that is useful to us. Thanks.
Yes, also in my opinion Maverick has serious problem. The ox is good but I have troubles also with other sw. I’m considering to come back to m_lion, but it is a really boring operation.
I think I’ll wait some days new upgrade from apple or some “fixed” by you.
you are great, thanks a lot!
Using 2013-11-13 (489) as of today and I have now lost the ability to execute functions from the command line. If I type for example _Mesh and hit enter I get nothing. Same for join, line, split. Previous version was all good.
_Box works however. Also just tried a simple Boolean Diffference but was unable to progress past the first object because the enter key is not registering. My Alias` appear to initiate but without the enter key registering I cannot execute some of them.
Software versions
Rhinoceros version: 5.0 Wenatchee 2013-11-13 (489)
OS X version: Version 10.9 (Build 13A603)
Plug-ins
None
Computer hardware
Hardware model: MacBookPro9,1
Processor: Intel Core i7-3720QM CPU @ 2.60GHz
Memory: 16 GB
Video hardware
Graphics: NVIDIA GeForce GT 650M OpenGL Engine
Memory: (null)
Screen size: 1920 x 1080
Displays: BenQ RL2450H
USB devices
None
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-8.18.22 310.40.05f01
Render version: 2.1
