Command Line Options Not Appearing in Rhino 7 Mac
Command Line/Tool follow up options not appearing when using any command after updating to Tahoe in Rhino 7 for Mac.
For instance, when I type Zoom, no follow up options appear. Same with the command Array; no array options appear in the command line, no toggle. When trying to create a Rectangle, I can click to set the opposite vertex, but no options to type a specified distance.
The effect (or lack thereof) is the same whether I type the command or select the command from the ribbon.
I can still type Zoom > E and it zooms to extents, but for any command that modifies or creates geometry that requires a follow-up selection, there is no follow up, and typing the follow-up command doesn’t work. (ie when I type Scale1d, no gumball appears). Tried restarting Rhino and reopening the file, no effect. Tried opening a brand new file, same problem.
Hi Tim,
Rhino 7 was developed way before Tahoe came out and is not a supported Mac OS. You’re going to either need to downgrade your OS to continue using Rhino 7 or upgrade your Rhino.
The changes were introduced in Tahoe were too big to backport.
