Command line fuzzy autocompletion not working in 9 beta
It seems the command line fuzzy autocomplete option is not working in rhino 9 beta ((9.0.26223.12303, 2026-08-11)) I checked and unchecked as well the echo prompts, the autocomplete and the fuzzy autocomplete. none off them changes it back. If I type a command it will autocomplete it but doesn’t give me all the possible other commands, which is one of the strongest points of command line ( I learned so many new commands, of found back commands i forgot :-))
lets get you on the latest
that solved it indeed
thnx
