Command IPlane or InfinitePlane
Do somebody know the german commando for IPlane or InfinitePlane or where I can find it as a symbol?
You can run the English version of your command with _(underscore): _IPlane
Here is an outdated list of commands in German:
https://wiki.mcneel.com/de/rhino/commandlist
Then, while in the command, press F1. that will get you the Help in German (if Rhino is running in German). There you will find the German name of the command and where it is in the toolbars/menus.
The command is called UEbene in German:
https://docs.mcneel.com/rhino/6/help/de-de/index.htm#commands/iplane.htm
Thank you. I tried it with underline and also with the F1 button. Worked!
