Windows 10 here.
Rhino 7, releasing the click of a drag action anywhere on the UI simply ignore the release action and will require future ESC or click to end drag action:
Rhino WIP, releasing the click behave like 7 in non-buttons UI elements, but will abort the drag action if the release happens over a button, and it will also execute the command of that button:
(personally, it doesn’t make sense to execute a button with just the release of a click, particularly while the user is instead dragging something. Past behavior like in 7 make more sense…)
This is a difference from WIP to 7 , but seems unrelated to what Bobi was referring to.
I can’t understand first post.
EDIT:
ok this seems really different and new on WIP.
You can start clicking anywhere in the UI that doesn’t trigger anything, but the release of the click will fully execute any button under the cursor.
Here I manage to “cut” the geometry by releasing the click over the cut button, but the initial click started somewhere else:
