Hi!
I have been using the QuadRemesh tool without any problem, until yesterday the dialog box that I attach in the image appeared, which says that the QuadRemesh command is not registered. The rest of SubD commands work perfectly for me. My version of rhino 7 is the 7.12. On my secondary computer, the command still works for me and the version that is installed is rhino 7.11.
Do you think the version has something to do with it? and if not, does someone know how to solve this problem?
Try running the 7.12 installer again and choose Repair. If that doesn’t fix it, it may be interference from an additional plugin you have installed. Compare what you are using on the other computer for plugins where QR works as well if that is the case.
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro 2000D (NVidia) Memory: 1GB, Driver date: 1-13-2018 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 377.83
> Accelerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 1-13-2018
Driver Version: 21.21.13.7783
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Next Limit\Maxwell for Rhino\maxwell_rhino.rhp “Maxwell for Rhino” 5.2.6.0
C:\Program Files\2Shapes for Rhino\7.0\2Shapes.rhp “2Shapes” 2.0.0.4
Thanks - that means that one of the two plug-ins (Maxwell or 2Shapes) is getting in the way of QuadRemesh. You can disable one-by-one and restart Rhino to find out which one it is and then contact the developer of that plug-in.
I have already tried to disable the plugins one by one, restart rhino and it does not work, then I have also tried disabling both at the same time and it keeps giving the error and therefore the tool still does not work.
Hi again, right now I am doubting that it is the fault of any of the plugins (maxwell, 2Shapes). On my secondary computer until yesterday that I had not updated rhinoceros, everything worked perfectly and at the moment I updated it, QuadRemesh stopped working
