Hi…,
the “extend with arc” option in Rhino 5 SR 6 connect command does only extend with lines and not with arcs.
Any ideas?
Thanks
Michael
flexiCAD.com
Hi…,
Any ideas?
Thanks
Michael
flexiCAD.com
I see not, the connect command extends arcs with arcs, but not curves with arcs, which would be nice.
Thanks
Michael
If I draw a curve and an arc. And use connect. They will connect. Just select 1 by 1 and it works.
Cheers.
Hi Michael- so, a free-form curve would be extended by a tangent arc of the same radius as the end of the curve, correct?
Yes, I think that should it do, or I am wrong?
Thanks
Michael
