Command, command, command panel name
I just downloaded the latest 9 WIP
System Info
Rhino 9 SR0 2025-10-7 (Rhino WIP, 9.0.25280.12305, Git hash:master @ 0a5e40a60821c67ce68d95a275fda420265d863f)
License type: Commercial, build 2025-10-07
License details: Cloud Zoo
Expires on: 2025-11-21
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 9.0.9
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 8-21-2025 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 8-21-2025 (M-D-Y).
- There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\import_PLY.rhp “PLY - Polygon File Format Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\ShrinkWrap.rhp “ShrinkWrap” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\import_STL.rhp “STL Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25280.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
In the top left corner in a new document I can now read the word ‘command’ three times.
The vertical panel name used to be just an array of dots which I found more elegant.
The main side bar on the left of the screen also doesn’t show the word ‘Main’ at least when it is docked. So maybe the Command panel also doesn’t need to show the name when it is docked?
Hi Martin -
I’m not seeing any difference in the latest version.
Have you tried restoring the default window layout to see if that makes a difference?
Unlocked:
Locked:
This is 9.0.25280.18305 but it was looking the same on 9.0.25280.305.
This only showed up yesterday after doing the update to the latest version 9.0.25280.12305
Restore to default window layout looks exactly the same it still says command.
Lock docked also doesn’t change anything.
Hi Martin -
What do you have the “UseEto” option in the TestEtoCommandUI command set to?
I changed this and it now looks as expected again. Thanks for your help
