Hi Yianni- as I see it, if you want the exact same result as Join followed by SplitDisjointMeshes, that assumes that edges and vertices match up in order for a Join to occur. IOn the other hand if Join is decided by proximity of the meshes as a whole, then intersecting meshes would be joined, two closed meshes that are very close to one another, or have coincident faces or vertices, would be joined… I’m not sure which is useful.
Join the copy and split disjoint as per my original script
Compare the results to the original meshes. Whatever is identical
geometry to original is what should NOT be joined. Put the rest of
the original meshes (to be joined) into an array
Delete the copied meshes
Join the meshes in the “to be joined” array
Whaddya think? Might it work? I don’t have time to script this right now, maybe later…
–Mitch
Large disappointment… The script was easy enough to write. It fails miserably however. Once 2 disjoint mesh parts have been joined and then re-split, Rhino.CompareGeometry (the equivalent of SelDup) no longer considers them identical… despite the fact that they are. Here’s an example:
mesh
Layer name: Default
Render Material:
source = from layer
index = -1
Geometry:
Valid mesh.
Open polygon mesh: 9 vertices, 4 polygons with normals
bounding box: (12.358,-23.1209,0) to (0,-18.3185,)
mesh
Layer name: Default
Render Material:
source = from layer
index = -1
Geometry:
Valid mesh.
I suppose there are other, more painful ways to check to see if the meshes are more or less identical, same number of faces, same vertices, but that’s plain painful…
Attached are 2 mesh planes and the copies via copy/join/split disjoint, can you tell me why they aren’t considered "identical?
–Mitch
