Command: _MatchSrf
https://docs.mcneel.com/rhino/6/help/en-us/commands/matchsrf.htm
Match Surface Options
Curvature __ percent
Curvature matching, in percent of the radius of curvature.
I’m trying to understand what the percent option means.
For example: curvature is default 0.05 percent
(A) Radius = 20 mm : The CURVATURE VALUE ( 1/Radius) would be 0.05
(B) Radius = 50 mm : The CURVATURE VALUE ( 1/Radius) would be 0.02
0.05 - 0.02 = 0.03 < default 0.05 percent
Thus, The two surfaces would be 100% curvature continuous?.. No?
Hi Knead - the % curvature refers, admittedly ambiguously at best here, to radius if curvature.
Pascal,
I’m I correct in saying that all these settings are meaningless unless you have the “refine” option set.
In other words, if you don;t have “refine” set you are going to get the same result no matter what numbers you fill in the boxes.
It is very difficult to understand what it means. :sweat:
Hi jim - I believe that is correct, yes. I have not actually tested though, in all these years of using it… I’ll see if I can come up with a meaningful test case.
Hi Knead - The radius of curvature of the surfaces should be the same to within that % at points along the matching edges.
for example:
(A) Radius = 20 mm
(B) Radius = 50 mm
20 mm VS 50 mm
Thus, 40% = Maximum difference in curvature between surfaces.
Does the percent mean to compare the physical size of the radius (20mm and 50mm), not the values of the curvature (1/radius = 0.05 and 0.02)? right?
The percent difference between 0.02 and 0.05 would be
100*(0.05 - 0.02)/(some measure of the general size of 0.02 and 0.05), for example
100*(0.05-0.02)/0.05 = 60%. Whether you use, the radius or the curvature the answer is roughly the same.
MatchSrf_Tolerance_percent_Knead_1st.3dm (354.2 KB)
in attached file:
(Blue) radius = 81.5069601 mm
(Red) radius = 81.4166767 mm
100 * (81.5069601 - 81.4166767) / 81.5069601 = 0.1107677183509633 %
When comparing Radius size in%, Matching tolerance exceeds 0.05%. :scream:
or
1 / 81.5069601 = 0.012268890887025
1 / 81.4166767 = 0.0122824959275205
100 * (0.0122824959275205 - 0.012268890887025) / 0.0122824959275205 = 0.1107677183512528 %
When comparing curvature in%, Matching tolerance exceeds 0.05%. :scream:
Thus, the radius or curvature of the matching surfaces have not the same within tolerance 0.05%. :cold_sweat:
What’s wrong with this? :dizzy_face:
The Curvature Difference Method.
Curvature Deviation = Curvature (Blue) - Curvature (Red).
Curvature is 1 / Radius.
Curvature Deviation = 1 / Radius (Blue) - 1 / Radius (Red)
In the attached file,
Curvature Deviation = 1 / 81.5069601 (Blue) - 1 / 81.4166767 (Red)
= 0.012268890887025 (Blue) - 0.0122824959275205 (Red)
= 0.00001360504049546093
= 0.00001360504049546093 * 100
= 0.0013605040495461 percent
Thus, 0.0013605040495461% is the same within tolerance 0.05%
Right? :fearful:!
Sorry, I was just pointing out that in your first example, with 20 and 50, your calculation was incorrect.
in attached file:
100 * (81.5069601 - 81.4166767) / 81.5069601 = 0.1107677183509633%
I thought the result of the matching surface should be within tolerance.
0.1107677183509633% > 0.05%
But, When comparing Radius size in%, exceeds 0.05%.
Is your problem in the numbers, or is there something wrong with your model?
Command: _MatchSrf
and
Check Refine match option.
Input Curvature 0.05 % percent
But, The radius of curvature of the surfaces was not the same to within that 0.05% at points along the matching edges.
Yeah, something isn’t right. We’ll look into it. I’m not sure this is a very good measure of accuracy.
