I am trying to do loft like the drawing below. I scaled lines between them but I don’t know how to insert(or combining together?) the scaled list to the original order within a tree so that loft works like my drawing.
Mine is on the right. It uses constant diameter pipes and the dreaded SDiff function, and it adds thickness (but no solid bottom) so a 3D print would be reasonably stable. As usual, HS_Kim’s solution is more elegant because his variable diameter grooves look better and he avoids using SDIFF. But it was a fun exercise nevertheless. Sweep2_re-bb1.gh (37.6 KB)
