Combine two lists
Hello everyone,
I would like to ask if someone can assist with the following:
I would like to combine two lists (Red & Blue) based on a third list (Yellow) - all lists have the same size - as shown in the following screenshot:
In more detail i have a list of 8760 hours (Highlighted in Yellow) where each hour has a 0 or 1 value.
I would like to combine the first two lists into one based on the 0 and 1 values. For every 0 value i need to get values from one list and for each 1 values get results from the other list. Is that possible?
According to your description, it sounds like what you are looking for is Pick’n’choose.
(Sets–>LIst–>Pick’n’choose)
Hi Kim,
Thanks a lot for your response.
The Pick n Choose works fine but i have an additional problem.
The lists i nwant to combine have 14 nodes. and 8760 values for each node (122640values)
The list with the 0 and 1 values has only 1 node and 8760 values.
The resulted list is correct buy it takes only the N=1 values. Can i do something to include all nodels (N=14).
Many thanks
Try to flatten your pattern input.
newbie question - what node is the one in Yellow?
Hi -
That’s simply a panel with a custom color.
