Combine number slider
Hi All,
I have two number slider, with value are 300 and 500. How to output to text is 300*500?
1
Thanks
do you mean you actually want it to say 500*300 in the panel?
if so, using the Expression component:
or, do you want it to do the calculation… (in this example, result = 150000)?
if so, using the Multiplication component:
Hi
Thanks Jeff
Expression compnent is command I need to solve my question.
As always, there are different ways of solving things…
Using Concatenate
And lastly, there’s a dedicated Format component which is basically a somewhat streamlined way to use the Format() expression. It allows you to specify the formatting culture as well, in case you need that.
Thanks wim and all so much
neat. haven’t noticed that one before
