Column sizes based on area
Hi Guys,
I am trying to create column sizes based on the area of each canopy. I have a minimum thickness and a maximum thickness. I am not sure how to apply this, but I have gotten this far. I don’t fully understand the logic of doing this.
Preformatted text
Any help or suggestions will be much appreciated!
Thank you!
Help1.gh (672.2 KB)
Maybe like that
Help_2.gh (673.6 KB)
This is perfect! Thank you Seghier! :slight_smile:
Hi Seghier,
As mentioned before, each of these columns moves down based on the volume (decay rate). I have the numbers in the script. Do you know how i would implement this?
Help_3.gh (674.1 KB)
Thanks again!
What you mean by move down? do you mean the height of the culumn?
Use min/max component , is better
https://rhino.github.io/components/heteroptera/minMax.html
You can also use python to get Min/Max number, this is not response of you last question just an update of the first response
Hi Seghier,
I have managed to create the script I needed.
Thank you!
