Colour glitches in Technical Display (Rhino 7)
Custom Technical display setup - visible and hidden lines colours are set to object colours. Hidden lines are switching from objects colours to red and blue when zooming out. Same issue is visible in the exported raster files/pdfs.
eg sockets are black, If hidden, color turns to red
and changed to red - blue when zooming out
zoomed pdf looks like this:
and modified technical drawing settings:
files:
https://dsc.cloud/6758bd/-test.3dm
https://dsc.cloud/6758bd/-test.pdf
Hello- please run the SystemInfo command in Rhino and copy/paste the results here.
Hm - it looks like objects are changing between hidden & not hidden, depending on the view.
Rhino 7 SR14 2021-12-28 (Rhino 7, 7.14.21362.13002, Git hash:master @ 343ac892b1825ce2fcd862b84d2d4629ddbe21ab)
License type: Educational, build 2021-12-28
License details: Cloud Zoo
Apple macOS Version 12.1 (Build 21C52) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro16,1
Language: en-GB (MacOS default)
AMD Radeon Pro 5500M OpenGL Engine (OpenGL ver:4.1 ATI-4.7.101)
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.1
  Shading Language: 4.10
  Z-Buffer depth: n/a
  Total Video Memory: 4080 MB
  Graphics: AMD Radeon Pro 5500M
  Displays: Color LCD (264dpi 2x)
Graphics processors
  Intel UHD Graphics 630 (1536 MB)
  AMD Radeon Pro 5500M (4 GB)
    Color LCD (1792 x 1120 @ 59.00Hz)
USB devices
  Apple: composite_device
  Apple Inc.: Touch Bar Backlight
  Apple Inc.: Touch Bar Display
  Apple Inc.: Apple Internal Keyboard / Trackpad
  Apple: Headset
  Apple Inc.: Ambient Light Sensor
  Apple Inc.: FaceTime HD Camera (Built-in)
  Apple Inc.: Apple T2 Controller
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /usr/lib/swift/libswiftCloudKit.dylib
  /usr/lib/swift/libswiftCoreData.dylib
  /usr/lib/swift/libswiftFoundation.dylib
  /usr/lib/swift/libswiftAppKit.dylib
  /usr/lib/swift/libswiftContacts.dylib
  /usr/lib/swift/libswiftCoreML.dylib
  /usr/lib/swift/libswiftVision.dylib
  /usr/lib/swift/libswiftNetwork.dylib
  /usr/lib/swift/libswiftFileProvider.dylib
  /usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
  /usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
  /Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	7.14.21362.1002
  /Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	7.14.21362.1002
  /Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp	"AnimationTools"	7.14.21362.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	7.14.21362.1002
  /Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp	"Displacement"	7.14.21362.1002
  /Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	7.14.21362.1002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp	"Import_OBJ"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp	"export_xaml"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp	"QuadRemesh"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp	"export_OBJ"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp	"Export SVG"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp	"Export_DAE"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp	"PDF Export"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp	"IGES Export Plug-in"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp	"Import_SVG"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp	"BlockEdit"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp	"Export_AMF"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp	"Import_DST"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp	"PLY - Polygon File Format Export"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp	"Import_AMF"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	7.14.21362.13002
  /Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	7.14.21362.13002
@bump
Hello- thanks - I now see the problem, intermitently.
RH-67246 Display: hidden objects change color in technical
