The Color Swatch component spawns with a Raspberry swatch that can’t be changed in 2.0.8126-wip.19400. The newer version of GH2 has mysteriously vanished from the PackageManager, but I still get prompted to install it when I start RhinoWIP!
This has already been fixed on newer versions. Maybe update rhino 8 wip?
I’m on the latest version!
The newer version isn’t available on macOS anymore (and I already installed it this morning).
Hmm, odd. I’ll push a new one out now, I fixed the loading conflicts between identically named GH1 and GH2 plug-ins which happened only on Mac.
Edit: it’s out now. Build for april 7.
I restarted my computer - it was off over night -, and I still can’t see any newer version, only the one from April 1st.
I’m not even kidding, but yesterday morning I had installed your first update with the interpolarity between both Grasshoppers via the PackageManager.
Later in the day, it had vanished from the PackageManager, which I noticed when checking for an even newer version, and mysteriously reverted Grasshopper back to the initial alpha release?
Now, when I launch RhinoWIP, it prompts me to:
When I hit Install, PackageManager opens and there’s no newer version to install.
I’d suggest that Rhino shouldn’t prompt users with “include pre-releases” turned off to install updates of pre-releases, or when hitting Install simply check it and show what’s to install, or even better simply install the update, instead of popping up the PackageManager.
