I tried to print using the “save as pdf” but could not get the colors to show correctly - they appeared to be double-printing (color overlays)hdw.pdf (406.2 KB) . I have attached the pdf. It seems to be related to the ghosted view.
If you want to show a color break in a cross section, I’d suggest using a ClippingPlane and then printing to PDF. This is working well here in a quick test on Rhino for Mac. The command EnableClippingPlane will make a clipping plane active in any viewport if you drew it in another.
I understand what you are saying, but something is weird because when I output the same file with the same settings on a pc, it looks totally fine. See page one of the attached doc.
NWS hardware specs.pdf (379 KB)
Thanks for the added info. I’ve filed this in our system for development to look into.
http://mcneel.myjetbrains.com/youtrack/issue/MR-906
