Color Picker (bug)
@pascal,
just found a tiny bug within the color picker. Please try these steps to reproduce:
  • create two objects
  • change wireframe object color for object one into blue
  • change wireframe object color for object two into red
  • select both objects and open the color picker
  • click the cancel button
On my side, the color is changed to white, for both objects. Same applies to the wip.
c.
I see the same, although in my case they both turn red. It seems that, even though the color picker dialog is canceled, the changes are not reverted. When selecting a single object, it works as expected, with multiple objects having different colors, this problem appears.
Fortunately, it is Undo-able.
Hi Clement- got that, thanks. The color picker defaults to white (or last used), from Properties, apparently, then ignores Esc/Cancel.
http://mcneel.myjetbrains.com/youtrack/issue/RH-31754
Thanks, funny we`ve never noticed it in all those years :wink:
c.
I’m sure there are more of those lurking…
